At this point is probably is moving, just very slowly. Watch the DRO to see if the numbers are changing.
"G98 F0.01" means feed at 0.01 inches per minute. At that rate it will take ten minutes to complete your move from X1.4064 to X1.6064.
4.50 Upgrade
- CNC Control System Serial Number: E8EB1128AAC4-0405180824
Re: 4.50 Upgrade
Thanks, I now have it moving.
Re: 4.50 Upgrade
Great!
Elaborate on what the issue was so we can bring closure to this thread.
Re: 4.50 Upgrade
The problem with the 4.50 upgrade is the fact that the ZIP File was corrupted when downloaded across the satellite. 4.50 would not take inputs or outputs correctly. Corrupted file .
Downloaded from fiber and the upgrade went smoothly.
When I tested my My cutting file it would not function ! I had the Feed rate set incredibly slow. Changed it per CNCKeiths instructions as I missed it and the file passed the operation test.
Re: 4.50 Upgrade
Great. Good you are going!
