Possible Bug in v4.50 when Probing with DP-4
Posted: Mon Jun 08, 2020 5:02 pm
Very pleased with the new version and hats off for the hard work which much appreciated
Have discovered a relatively minor issue, using Mill version fully configured with Digitising licence and updated from 4.20.1
After successfully probing a bore, disconnecting the coiled probe lead causes the menu items at bottom of screen inside "Part" section to flash. Reconnecting the lead stops the flashing but disconnecting the lead it restarts. Main Menu is not affected but Parts section will flash upon re-entering. Restarting CNC12 stops the issue until next probe cycle
Have performed 2 clean installs initially with Restore Report and subsequently (following fresh download) keying in parameters manually from screenshots. Flashing persisted in both cases.
Reverting to previous version 4.20.1 does NOT exhibit this problem.
Steps to reproduce:
- Following fresh install, boot up Control and CNCPC
- Home Machine
- Fit DP-4 to spindle and Connect cable
- Perform simple Bore Probing cycle in Part section
- All correct at this stage so return to Part section
- Disconnecting lead to DP-4 at this point will cause menu items to flash
Have attached short mp4 video showing flashing and usual report
Steps to reproduce:
- Home Machine
