hello I have installed the new version 4.5 and when verifying the version this version 4.14 appears to me, why is this?
Re: Acorn CNC12 version 4.5 has been released!
Posted: Mon Jun 29, 2020 6:23 pm
by ShawnM
Glad to hear it Edward, someone here always has the answer because they've been there or done that.
Posted: Wed Jul 08, 2020 11:07 am
zgkonig wrote: ↑Mon Jun 29, 2020 5:45 pm
[/img]hello I have insta20200629_173746.jpglled the new version 4.5 and when verifying the version this version 4.14 appears to me, why is this?
try and and follow the instructions carefully. that is v4.14 not v4.5
Posted: Wed Jul 15, 2020 10:17 pm
by CSXAL
Hey Keith, Do you know if there is a bug with updating to 4.5 from 4.20.1 and 4.5 not taking the import of Pro license? I upgraded today from 4.20.1 and I have the pro version and even after importing license dat file several times, it is not changing software from free version to Pro? I emailed into support earlier today and didn’t get a response on correcting issue. Without it working as pro, my MPC pendant isn’t working.
Al
Posted: Thu Jul 16, 2020 1:03 pm
by CSXAL
Keith,
I called the office this morning and they just emailed me a new license number. That one worked.
Posted: Sun Jul 19, 2020 9:16 am
CSXAL wrote: ↑Wed Jul 15, 2020 10:17 pm
Al
hello. there are no bugs related to reusing your existing license file. be sure NOT to use an Apple computer to download the Acorn License file or transfer it to USB stick etc..
Posted: Sun Jul 19, 2020 8:35 pm
by knastenrad
Finally i also got the time to update to 4.5.
Went smooth upgrading from the previous version
I really like the new look and added functions .
Thumbs up!
Also added a couple of functions to show Probe tripped , and Tool Touch with indicators on the VCP.
However after entering parts setup-->probing, i saw a new feature that i assume shall show the probe tripped.
This does not show anything even if the indicators i added works (the "probe" and "tool touch off" works)
Do i need to have the "Probe and Tool touch off detect" inputs activated for this function to show in the part setup-->probing menu?
( i do not have these inputs activated now, probe still works)
video:
attached report
Posted: Mon Jul 20, 2020 11:22 am
knastenrad wrote: ↑Sun Jul 19, 2020 8:35 pm
Thumbs up!
Thumbs up!
attached report
hello. are you using a NC or NO touch probe?
The probes(both touchprobe and toolsetter) brakes contact when triggered , so the contacts in the probe is NC then
Posted: Mon Jul 20, 2020 7:17 pm
by swissi
knastenrad wrote: ↑Mon Jul 20, 2020 5:01 pm
You need to read the Probe Setup Guide. A Touch Probe of type NC is only supported with a ProbeDetect Input.
The Touch Probe does work without a Detect Input and nothing bad happens as long as you keep the TP connected. As soon as you disconnect the TP, CNC12 will see this as a Probe Tripped signal and will engage probe protection.
While CNC12 still recognizes a trip signal from an NC type TP without a Detect Signal, the Probe Image on the CNC12 Probing page does not show a trip when the Detect Signal is not present.
-swissi
UPDATE:
When I said "nothing bad happens" above, you need to be aware that any TP setup without a Detect Signal does not enable the Spindle Inhibitor. That means if you have the TP mounted in the Spindle with a cable attached and you turn on the spindle by accident, it might destroy your cable or even your TP.
