Page 2 of 5
Re: Acorn CNC12 version 4.5 has been released!
Posted: Mon Jun 15, 2020 12:53 pm
Edward, hello. the F3 is default (is hard coded) is changed by specifying the F rate you would like on the G code line to this changes the default from 3 to what you require. :-))
Posted: Mon Jun 15, 2020 7:55 pm
by DrLocke
Followed instructions, checked everything, no issues, looks operational.
Posted: Wed Jun 17, 2020 11:57 am
DrLocke, thanks for reporting back!
Posted: Fri Jun 19, 2020 9:55 am
by rflopes3
I will make the upgrade toaday but I have a little question. What about the license ? Creating the report will also carry on the license as well ?
Posted: Fri Jun 19, 2020 11:24 am
by swissi
rflopes3 wrote: Fri Jun 19, 2020 9:55 am I will make the upgrade toaday but I have a little question. What about the license ? Creating the report will also carry on the license as well ?
Yes it will.
-swissi
Posted: Sat Jun 27, 2020 11:41 am
by Rut24
Hey Keith,
Just installed ver. 4.50 with no issues.
Love what has been done with the VCP. Everything is much clearer now for us DIYers
Keep up the great work on making Acorn more user friendly.
Thanks :D :D
Posted: Sun Jun 28, 2020 2:04 pm
by DY10CNC
Hello & HELP!
I just added a couple of push button normally open switches to make use of the Wizards new features - 2nd Cycle Start and 2nd Feed Hold.
Input 3 for 2nd Cycle Start and Input 4 for 2nd Feed Hold.
They work fine, But I've lost cycle start and feed hold on the VCP - ALT S - Spacebar and MPG.
What am I doing wrong?
I followed procedure - cycle Acorn re-booted CNC 12 etc.
Attached are reports from before and after changes.
Thanks in anticipation of your help.
Edward
Posted: Sun Jun 28, 2020 2:49 pm
by ShawnM
Hi Edward,
I had the same issue when I added a pushbutton to input 7 for a second cycle start. I was instructed to go into the diagnostics screen, Alt-I, and invert the input that you used for those inputs. Here's a link to the PDF.
https://www.centroidcnc.com/centroid_di ... creen.pdf
I know someone will be able to explain it far better than I did but this should get you going.
Shawn
Posted: Sun Jun 28, 2020 4:31 pm
by DY10CNC
Hello Shawn,
Thank you for your suggestion and the link to the PDF.
I will try your suggestion tomorrow. (21:18 here in England)
Thanks again Shawn, I will update you tomorrow.
Edward
Posted: Mon Jun 29, 2020 3:25 pm
by DY10CNC
Hello Shawn,
2nd Cycle start etc - SORTED!
Followed your instructions and my start and feed hold work fine.
Checked the wizard setting after making changes in ALT I information screen and found that my inputs now show as normally closed.
Counterintuitive but works so thanks a bunch!
Where would we be without the forum members and guys like Keith at centroid!
best regards,
Edward
