No servo Motion
- CNC Control System Serial Number: 190201
Re: No servo Motion
I have watched this several times. During my desktop start-up - there were problems getting the motors to operate. While connecting with Gecko to solve the issue -p being it was taking a bit of time to make dicovery. I moved the componets out to the lathe - need the desktop (Autocad station). Leaving the drives dissconected. So after multiple calls - things were changed from the video. ports 8 and 9 wires were switched - port 5 is open - then one motor was getting power and lights all went green, found a pod to be ajusted on the non working drive, now holds spindle from turning. Shows both motors are getting power - just receiving no signal for rotation. I then added the prox switches - maybe it needed to go home. Still no rotations. Sometimes when I turn on the machine, I see the Dell name then goes to black screen. I need to restart - eventually it comes back on to desktop with icons. Did this to me on the test runs on the desk start-up too. I have 2 other machines with centroid - they don't have this problem - just tunr on once.
Re: No servo Motion
It seems to me you need to drop back to a basic benchtest and make sure your PC and Acorn can communicate reliably.
You have to be sure your G320X and motor/encoder are configured properly or no amount of monkeying around with Acorn is going to get it going.
I do not recommend novice users try and setup DC Brush servos.
If I were you, I would consider buying some Leadshine Closed Loop Steppers. CNC4PC.com is a dealer and Leadshine USA will drop ship them.
Just because a machine came with DC Brush servos (old technology now) does not mean you should pursue trying to use them.
- MPU11 & GPIO4D -w/ 3rd Party Drives: Yes
7804732B977B-0624192192 - Location: Boston, MA
Re: No servo Motion
It also sounds like you have a PC problem. Acorn in no way will affect the PC booting. Seeing the Dell logo and then black screen means Windows did not boot correctly. Getting your PC fixed should be your first task before trying to trouble shoot your CNC parts.
