Acorn Wiring Question -- +24 VDC Power from H9 to H4
briuz
Post by briuz »
Hello!
In the wiring diagrams +24VDC is ran from connector H9 to connector H4 to power the input circuits at H1 and H4. Is there a reason this power wire is ran external to the board and not part of the board?
Thanks!
Richards
Re: Acorn Wiring Question -- +24 VDC Power from H9 to H4
Post by Richards »
The Acorn User Manual has an explanation. It allows you to use an additional power supply, if required by your devices.
-Mike Richards
briuz
Post by briuz »
Thanks! It looks like I need to spend more time reading the instructions....
We are collectively working on an Acorn Installation manual and hopefully, that information will be included for reference.
Richards
Post by Richards »
There are bits and pieces of information that help but it's kind of spread out. I make it a habit to save anything I run across. After a while, it helps.
-Mike Richards
