Dear Acorn creators,
My Emco Compact 6P Acorn conversion gets slowly towards its end and an Emco F1 mill is already waiting.
So I got a question for you:
If the mill spindle would get an encoder would the mill software & Acorn be able to run the spindle synchronous with the 4th axis (or any other) ?
My guess is that it is pretty much what the lathe software and the Acorn are doing during threading and it should be possible - however my confidence level is not at 100%.
Just to make the thought more realisitc: Imagine a gear hobbing process with the hob in the spindle. This would require that the spindle and the 4th axis - which turns the blank part - run synchronous (and yes I know for such a small mill this is an unusual process but it's meant to be for a quite small modulus in the 0.5 mm area).
I am looking forward to your appreciated answer.
Best regards from Germany & stay healthy !
Andreas Jauss
Acorn Mill Pro - Encoded Spindel & 4th Axis Synchronization
- CNC Control System Serial Number: 74E182762556-0907181197
Re: Acorn Mill Pro - Encoded Spindel & 4th Axis Synchronization
... time to order another Acorn board - but the question is still open before.
The task is very similar to rigid tapping or lathe threading but it would be nice to get a confirmation as I haven worked with the mill software so far.
Thanks in advance.
A. J.
Thanks in advance.
A. J.
Currently CNC12 does not support the spindle synchronized with any other axis than Z. Hobbing is on the to-do list.
Thank you Tom.
Hope is no methodology - so I am going to think about a workaround as I like to stay with the Acorn.
I am pretty sure to get step (& direction) signals with the desired ratio to the spindle encoder to the 4th axis motor.
So the 4th axis would get some own electronics & programming.
If the Centroid developers work through the hobbing item first then it's even better.
So I will place another order.
Best regards
A. J.
Best regards
A. J.
... order placed.
