Shinosky wrote: ↑Wed Apr 08, 2020 2:52 pm Thanks to all who have helped me here. I feel as though I have made a huge amount of progress. I was actually cutting parts today even though I know I still have some lingering noise issues. They all stem from the Motor/VFD I believe. My noise issues all disappear when the spindle is off. I have taken every step I know of to eliminate the interference. At this point I suspect the VFD is creating an enormous amount of noise. I have relocated it as far from the existing data lines as is practical. The machine runs but when I check the error log I see I am getting a ton of MPU resend requests. I don't think I am getting them with the spindle off. I have also tested the ethernet connection with all the inputs and outputs unplugged. A basic bench test. No issues.
SO:
Does the length of the power cable leading into the VFD have a bearing on noise? Mine is like 15-18 ft long and it runs under my machine to the outlet. It does run through an EMI filter prior to entering the VFD. My output cable is a shielded VFD cable.
I am thinking of trying a new VFD at this point. Does anyone have a recommendation? I have a 1.7Kw HSD air cooled spindle.
I am powering it with 240V single phase
My existing VFD is a Mitsubishi A800.....I think the 800 stands for the cost:) ...I know this thing is about that much money to buy. It is so complicated. It literally has around 1500 parameters. It's a nightmare for non electrical guys like me. But I need to try something else. Don't know what else to look at at this point.
Hey Shinosky,
I've converted a bunch of shopsabre machines to centroid (Oak + servos though). The mitsubishi vfd's work just fine as long as the proper types of cable are used and they are shielded/grounded properly.
