Which HY VFD do you have? HY or GT?
Attached are my notes, they may help you get started.
Hellou Marty. I have folow all your instruction on this forum and YouTube and everything works perfect. Today I have made my fist piece. Everything works so good.martyscncgarage wrote: ↑Mon Mar 08, 2021 11:17 amWhich HY VFD do you have? HY or GT?
You need to start your own NEW TOPICsahtijan wrote: ↑Sat Apr 17, 2021 6:10 pmHellou Marty. I have folow all your instruction on this forum and YouTube and everything works perfect. Today I have made my fist piece. Everything works so good.martyscncgarage wrote: ↑Mon Mar 08, 2021 11:17 amWhich HY VFD do you have? HY or GT?
But I have one little problem.
When I recall g code, same tool, same G54, same g code, same piece, my WCS G54 moves a litlle bit in negative direction,(all 3 axis) .I use Acorn Pro a it is router without atc.
Do you know what can be problem.
