CNC12 v4.18 Acorn Spindle Fault
Posted: Tue Mar 03, 2020 12:44 am
I am confused about the correct wiring of a HuanYang VFD to Acorn board.
After searching the forum I find a post where Marty says "There is an error in the HY Schematic, use FB & FC".
Then I checked the following 2 schematics:
S14898-ACORN_rev3 HUAN YANG VFD.pdf dated 180427 shows VFD FA goes to Com and FB goes to DriveOK (Input5 on the Acorn board).
While S14984-ACORN_rev4_HUAN_YANG_VFD.pdf dated 191022 shows VFD FA going to Spindle OK (again Input5 on the Acorn) and FB going to Com.
This is quite a difference.
I have wired my system using the latter diagram: FA ==> Input5 and FB ==> Com but this gets me a Spindle Fault message.
I would try the other diagram but I'm concerned I would screw up Acorn.
The VFD/Spindle works fine in manual mode.
Anybody with a HuanYang VFD and Acorn care to suggest what I should try?
John
John
