After setting the master Z reference pre-setting o/d tools works fine
If you try to set an i/d tool the offset usually moves by . 01mm or so
If you describe the i/d tool as an o/d tool and re measure it works fine and gives you the correct offset
I had to measure all my tools as o/d and change them back to i/d after measuring them
See the screen shots on tool 14
Is it a bug or a basic setting that has not been configured
lathe tool setting
- CNC Control System Serial Number: 38d2693c4f62-0725181074
Re: lathe tool setting
This sounds like same issue I am having when trying ID boring bar when I switched to fface works for z but my x still gets way off and have to add double the thickness of my tool setter probe
Joe
Joe
My x works perfectly fine for Id tools
As always before we can answer this correctly PLEASE send a report.
Dana
Dana is Centroid's lathe guy.
He is correct ALWAYS post a fresh report for assistance.
just attached it
- report_C8FD19C4742C-0309180722_2020-02-22_15-45-07.zip
- (331.91 KiB) Downloaded 213 times
