CNC12 Threading (Resolved)
Hi, is it possible to do threading in CNC12 free software using G code in intercon?
Thanks.
Thanks.
Re: CNC12 Threading
Threading will require a spindle encoder 1:1 with the spindle and Centroid Lathe Pro available here:https://www.centroidcnc.com/centroid_di ... oller.html
Re: CNC12 Threading
It's difficult to tell from the website info, but I believe based on experience that is, no.
You have to have encoder feedback and that is available in Pro only.
Clay
near Winston-Salem, NC
Re: CNC12 Threading
NO threading or rigid tapping with out the PRO version of the software. And yes you also have to have a differential encoder belted to the spindle with a timing belt at 1:1
Re: CNC12 Threading
Thanks for all the replies. I do have an encoder which works in the free version as well. But, looks like I will have to upgrade to Pro for threading. I tried adding G76 codes into intercon program, but it stops when it hits the threading code.
Re: CNC12 Threading
Does the software not tell you to upgrade to Pro when it hits those cycles?
Re: CNC12 Threading
Yes, it did.martyscncgarage wrote: ↑Sun Feb 16, 2020 9:11 am Does the software not tell you to upgrade to Pro when it hits those cycles?
Re: CNC12 Threading
The features work provided you have a good differential line driver encoder belted at 1:1 to the spindle with a timing belt.manojd wrote: ↑Thu Feb 20, 2020 10:34 amYes, it did.martyscncgarage wrote: ↑Sun Feb 16, 2020 9:11 am Does the software not tell you to upgrade to Pro when it hits those cycles?
Good luck!
Re: CNC12 Threading (Resolved)
Got everything working. Threading works wonderfully after setting parameter 240 to -1. I can do internal and external threading. I do have one concern, the internal threading bar(s) seem to approach/retract much more than expected. I need to do really tight internal threading. I did set the approach and retract parameter in intercon, but it does not seem to take effect.
Awesome!manojd wrote: ↑Wed Feb 26, 2020 12:43 pm Got everything working. Threading works wonderfully after setting parameter 240 to -1. I can do internal and external threading. I do have one concern, the internal threading bar(s) seem to approach/retract much more than expected. I need to do really tight internal threading. I did set the approach and retract parameter in intercon, but it does not seem to take effect.
Post the code, and a report
Clay
