Hi Marty
I watched a video yesterday from you at YOUTUBE and I saw you make the connections from the power supply to the Acorn and to the E stop switch and for the power supply for the servo drive, and you connected all COM together and used a block, I have problem before with my cnc control that when I turn the power off the servo jump the position, I don't know If you remember, I send to you a video before on YOUTUBE.
But after I watched your video I when take look my connections and I saw that I not connect all the COM together like you did, from the COM of Acorn power supply you put a jump wire to the drive power supply and to the connection block.
Do you think because I not did the same may cause the problem? If yes let me know please and I change the wires because I put a switch between the power supply and the driver for me turn the power off the drive before turn the power off on Acorn board.
Thank you
Wagner Damotta
COM wire connections
Re: COM wire connections
Wagner,
post a photo of your setup, what kind of motors and drives are you using, link to the manual? etc..
post a fresh report.zip.. follow the posting guidelines here..so we can help you. viewtopic.php?f=60&t=1043
and in general follow the Acorn hookup schematics https://www.centroidcnc.com/centroid_di ... matics.zip
Wagner,wagdamotta wrote: ↑Sat Feb 08, 2020 6:19 pm Hi Marty
Thank you
Wagner Damotta
I vaguely remember. As Keith said, please post the information requested.
I tie my power supply commons together.
hi
I have DMM DYN2 servos.
report_38D2693D7A14-0118180556_2020-02-11_17-15-42.zip
Thank you
Thank you
Hi
I have the DMM - DYN2 servos
Thank you
Wagner
Thank you
Wagner
- report_38D2693D7A14-0118180556_2020-02-11_17-15-42.zip
- (334.43 KiB) Downloaded 152 times
Wagner, did you ever consult with DMM about this problem?
I believe they were aware of the lurch but may have corrected it with a firmware update. But I only experience this on power up not power down.
FWIW, I've had good luck contacting DMM by email at: info@dmm-tech.com
Generally I've gotten a response in less than 24 hours, including over weekends.
