SPIN BRAKE to vacuum ON/OFF
- CNC Control System Serial Number: 3905
Re: SPIN BRAKE to vacuum ON/OFF
Sorry Gary I meant that the names are NOT OUTPUT5 & OUTPUT6.
Are the outputs configured to "OUTPUT5" and "OUTPUT6" or something other than that? My code works for an output configured as the generic "number", Marty's works for one configured as an internal function
Have you read the Acorn install manual? The procedure is in there on page 50. Please take the time to read the install manual as it will answer all the basic setup questions for inputs and outputs. Then read the VCP manual, it will help you customize those output buttons.
fma1955:
Please take the time to follow this post, which includes posting a FRESH report when you ask for help
Your report has much information about your machine's configuration and how you have the control setup.
viewtopic.php?f=60&t=1043
Also, please make sure you are upgraded to the latest software revision which is 4.64
It can be found on the download page:
(Take the time to create a fresh report and get screen shots of all your Wizard pages before you do the upgrade. I recommend a fresh install)
Here are the installation instructions:
When they are configured as OUTPUT5 & OUTPUT6, then my macros will work, assuming you change the "2" in the example to 5 and 6.
A close relative bought me this shirt. Not sure what she meant by it!!!
By the way that you for the reference.
ShawnM wrote: ↑Fri Nov 26, 2021 10:17 amHave you read the Acorn install manual? The procedure is in there on page 50. Please take the time to read the install manual as it will answer all the basic setup questions for inputs and outputs. Then read the VCP manual, it will help you customize those output buttons.
Thank you VERY much Gary. I will try it again on Monday.
Thank you Marty for your links.
"When they are configured as OUTPUT5 & OUTPUT6, then my macros will work, assuming you change the "2" in the example to 5 and 6."
