SPIN BRAKE to vacuum ON/OFF
- CNC Control System Serial Number: 7804732CDADC-0123191572
Gey guys , i have another question as im not using Spindle break, and i think not many ppl are using that.
How can i change this Spinbreak to Vacume on off, On virtualjogpanel ??
And is there any Keyboard Shortcut to control that ?
Re: SPIN BRAKE to vacuum ON/OFF
You can create a Macro to turn on an output. You need to choose what M code you want to use. You can then program one of AUX keys on the VCP or the wireless MPG.Martin Zarnay wrote: ↑Wed Feb 05, 2020 9:10 am Gey guys , i have another question as im not using Spindle break, and i think not many ppl are using that.
I did a Phoenix 4x4 router a while back, I used M35 to turn it on and M36 to turn it off. I used Output 4
In the M36 Macro, there is a delay of 3 seconds. This clears the hose after the router motor is turned off.
See the G4 P3 line in the Macro:
;SET DustCollectionOn = M35, RST DustCollectionOn = M36
;mfunc36.mac
G4 P3
IF #50010 ;Prevent lookahead from parsing past here
IF #4201 || #4202 THEN GOTO 100 ;Skip macro if graphing or searching
M95 /35 ;Request to RST DustCollectionOn
N100
Yes you right, I should do that with different button than this one. Ans start writing macro
Here is the M35 Macro. I have not tested with 4.20.1
;mfunc35.mac
M94 /35 ;Request to SET DustCollectionOn
N100
;mfunc35.mac
N100
- CNC Control System Serial Number: 3905
Hello Marty,
I have had virtually no experience with macros. I want to use buttons 1 & 2 on my MPG to turn the Dust extractor & Vacuum table on. Will this code work (as is) by placing it in the code of one of the buttons? If not do you know if anyone has written the macro to do such for the MPG. Thank you for any help in advance.
Here is some sample code I use to toggle an output: (change the "2" to your preferred output number) This allows the same macro button to turn an output on or off, depending on its existing state
N100
IF #60002 THEN GOTO 300 ; the "2" in #60002 is output #2
N200
M62 ;the "2" in 62 is output 2
GOTO 1000
N300
M82 ;the "2" in 82 is output 2
N1000 ; end
N100
N200
GOTO 1000
N300
N1000 ; end
Thank you very much Gary,
Is that code right for the WirelessMPG which I forgot to say I have?
Gary Campbell wrote: ↑Wed Nov 24, 2021 11:07 am Here is some sample code I use to toggle an output: (change the "2" to your preferred output number) This allows the same macro button to turn an output on or off, depending on its existing state
N100
N200
GOTO 1000
N300
N1000 ; end
I don't know if it is different but using the code on my WirelessMPG will turn the light on ports 2,3 & 4 by changing the number you indicated. Ports 5 & 6 are the ports that have my Dust ext. & Vacuum on. When I change the numbers to 5 & 6 nothing happens.
Thank you for your help.
N100
N200
GOTO 1000
N300
N1000 ; end
Are the outputs configured to "OUTPUT5" and "OUTPUT6" or something other than that? My code works for an output configured as the generic "number", Marty's works for one configured as an internal functionWhen I change the numbers to 5 & 6 nothing happens
Yes they are Gary in (Output definitions) but I don't know how to change them. Clicking on them or double clicking does nothing.
Thank you
Thank you
Gary Campbell wrote: ↑Thu Nov 25, 2021 11:28 amAre the outputs configured to "OUTPUT5" and "OUTPUT6" or something other than that? My code works for an output configured as the generic "number", Marty's works for one configured as an internal functionWhen I change the numbers to 5 & 6 nothing happens
