Hi lads!
I recently build a pc to run only my acorn. I install the software that far everything is ok. I am loading the program press cycle start and pop up a window with a message “913 could not open the file”.
How can i fix that.
Thanks in advance
913 fault (RESOLVED)
- CNC Control System Serial Number: 7804734CD6F8-0320191789
Re: 913 fault
You should post a report.Supermario wrote: ↑Fri Jan 31, 2020 6:49 pm Hi lads!
How can i fix that.
Thanks in advance
How are you "loading" the file?
Clay
near Winston-Salem, NC
Re: 913 fault
Along with your report, can you post a screenshot of the error message?
What is the exact file name?
Re: 913 fault
I did a search on the Internet for a Windows 913 error. This is what I found:
"Error 913 and other critical malfunctions can arise when the Windows operating system becomes overloaded with invalid system references, corrupted or missing registry files, malware and outdated device drivers. These problems commonly occur due to a lack of regular PC maintenance. As a computer operating system gets older, errors and crashes start to become more frequent and problematic."
-Mike Richards
Re: 913 fault
And the version from the CNC12 manual:
Which is why I asked for a screenshot, to see if it was a Windows or CNC12 error message
Re: 913 fault
thanks a lot for your help! sorry for the late reply.
problem solved!!
i dont know why but when the program is out of this folder ''cnct > ncfiles'' it can not run and i have the alarm.
when i move it to this folder i had no problem at all and program run normal.
problem solved!!
