Tapping Threads -- Question re 115 VAC VFD
Re: Tapping Threads -- Question re 115 VAC VFD
If "increment" is less than depth, then it will peck tap.
https://www.mcmaster.com/machinable-wax
BTW, McMaster sells machinable wax in small pieces Cheers,
I've got Intercon Lathe 4.20 and don't have the Increment option available. I am not sure why.
Oops. That was my mistake. I forgot we were talking about a lathe. That image is from Intercon Mill and you are correct that Intercon Lathe does not have a peck option.
@CNCKeith - is there a reason why Intercon Lathe doesn't have a peck tapping cycle? Or are bruiz and I missing something?
In the video I posted, in the other thread (viewtopic.php?f=60&t=4009) I just "stacked" two tapping cycles and it threaded like peck tapping. The first tapping cycle is to 0.250 and the second tapping cycle is to 0.500. Works fine. A "peck" option would be nice, though.
