Thank you very much for your service. No problem about so long getting back. We understand that we all have other things to do also and may not be able to check things out, make changes and then get back right away.JerryLouisMartin wrote: ↑Sat Jan 11, 2020 12:05 pm I have changed the configuration and homing on the lathe.
It now homes to the right and all setting are functioning per your guidance and direction.
I still cannot get the intercon to do run time graphics even though it is turned on.
Tested the intercon to do a straight turn from diameter stock of 1.25 to .75.
Will only run to line 23 and it sits right there. No run time like in the videos!
Haven't figured out the why yet!
I apologize for not posting a response sooner as I'm a disabled Vet and
I Have really bad days where I do not do much! Again, I'm sorry!
Intercon will not show Run Time Graphics. It will graph the program and give you any error messages if there is any error in the Intercon cycles. Run Time Graphics only displays when you press Cycle Start to run the program from the Main Screen. Are you running the program when you say it just sits there at line 23? What are the messages that are displayed in the message box?
PLEASE SEND a current Report and the Intercon program you have written.
