Homing the machine
Homing the machine
At the moment finally got all limits working. All axes are moving and as a added
bonus they are moving in the correct direction.
Let me first say I did a searches. How do you command the software to home all axes.
Sorry for the stupid question.
Thanks to all that helped with my previous issues.
Re: Homing the machine
Go into the wizard and change from simple home to home to switches
post a fresh report.zip so we can see your settings.
Well more success. All axes homed. The X axis moved in the positive direction. Is that correct.
Thanks for the help
Thanks for the help
On a lathe or mill, maybe. On a router, not usually.
On the homing page, and once "Home to Switches" is enabled, select "M91-" or "M92+" to set proper direction for your machine and switch setup
Like Keith said, post a fresh report and or screen shots of your Wizard Homing page.
Sure would be of more help to us to help you....
Here is the report.
You can home the machine however you like. Its up to you. Its a reference point for the control.
You can change that by making sure the home switch is in the proper position and changing it as Gary mentioned. The Homing screen in the Wizard is for setting that up.
Let us know if you are OK or you need further help.
beebee,
what drives are you using? and what steps setting is being used on the DRIVES?
thanks for posting the report. the report shows Steps per rev with numbers that i question.
you probably should read over this information
viewtopic.php?f=63&t=1801
and watch martys videos on the same subject contained in this video series.
viewtopic.php?f=61&t=1449
and Tech Bulletin on how to calculate turns per inch. https://www.centroidcnc.com/centroid_di ... ads/36.pdf
Ball screw 5/8 .25 lead.
Z axis 3 to 1
X axis 2.5 to 1
Y axis direct drive.
US Digital Encoder. E2-250-250 EG. It is 250 line count, which will provide 1000 pulses per revolution using x4 quadrature counting.
Update 1/8/2020
Gecko 320 x driver. Update 1/8/2020. Step Pulse Frequency is 0 to 300 kHz
DC brushed Servo. Max operating speed 4800
Continuous torque OZ-IN 170
Peak torque 850
Terminal voltage max 90VDC. I’m supplying the motors with 72 VDC
steps / revolution all three are set to 1000
turns are ...x 10...y4.....z....12
Here are Max Ouput Settings of 100,000.....200,000....400,000
Which should I be using.
Z axis 3 to 1
X axis 2.5 to 1
Update 1/8/2020
Peak torque 850
