I have my conductive tool touch probe working well now and want to move on to the Z part probe function.
It is a home-made NO opto based plunger that loads onto the QCTP for setting the part Z-zero. I saw several different Z setting macros for routers (which i suppose would work) but so far I haven't seen one for a lathe. Much of what I do is the repairing of existing parts and being able to touch off on the various odd features accurately saves time. I had it working well in Mach3 with a simple macro but my brain has aged since I had that set up some time ago.
Can any of you fellers out there point me in the right direction? No big hurry, I'm sitting around in SWMBO's hospital room 'til tomorrow at the earliest & can't stop thinking about this stuff. (She's fine now; they're monitoring things & tweaking her meds for the next 24 hrs. before they kick us out.)
Simple Z probe part macro for lathe?
Milton in Collierville, TN
Re: Simple Z probe part macro for lathe?
Sorry about not responding sooner. I was going back through my e-mails and saw that no one had responded to this.
I have attached to 2 files. The first one is Lathe Probe Z.txt. This is the macro that probes and set Z0.0 or a Z value that you want that surface to be. It will prompt you to jog X to the Diameter that you want to probed Z in and prompt you to jog Z within .125" (3 MM) of the surface. You will press cycle start and Z will be set then pull Z away from surface by clearance amount. The second file is the macro that can be used by one of the AUX keys to run the file "Lathe Probe Z.txt". It is written to use AUX 10 key. If you do not have AUX 10 already used you can change parameter 197 to = 6111. If this AUX key is already use you can use one of the other AUX keys (parameters 188-199) that are not used and make it = 6111. If you already have mfunc61.mac you will have to change this mfunc61.mac to a different M function number and change the parameter so the first 2 numbers match the number in the mfunc__.mac file.
I hope everything is okay at home now.
- Lathe Probe Z.txt
- Probing Z
- (4.19 KiB) Downloaded 99 times
- mfunc61.mac
- Macro to call Probing Z
- (587 Bytes) Downloaded 105 times
Dana
Thanks Dana; that's exactly what I needed! My Aux 10 button is wide-open & ready for duty.
The wife is home now & doing well, thanks. I'll know if she's really back to normal when I head out to the shop after supper to try out the macro.
Just to be save have the probe further away from the part and trip by hand to make sure everything is okay. I have been running this with the DP-4 on the Centroid servo lathe.
Dana
