you must first run a program and interrupt it by pressing ESC or Cycle Cancel or Estop for the F1 resume Job Function key to appear in the RUN menu.
glad you found out the mechanical problems with the machine.
missing function in F4 run, attempt at easing binding axis, maybe worked
Re: missing function in F4 run, attempt at easing binding axis, maybe worked
