Complete newbie here. I was bench testing my Centroid Acorn/Dyn2 controller box for a soon to be purchased CNC router. Software pairing on the Y axis was successful and the two servos jogged in unison, with the slaved servo moving equal and opposite the Y servo. I tried to use a G code instruction (g0y1) in CNC12, as seen in one of Marty's videos, but only the Y servo moved (the slave didn't) and the pairing was no longer in effect. I had to exit CNC12, use the Wizard to re-pair the axes, and then restart CNC12. This was a consistent result in more than 5 attempts.
My expectation was that the result of the g0y1 command was that both servos would move, but in opposite directions.
Do I misunderstand what should have happened?
Software Axis Pairing and G Code
- report_7804732BCC31-0227191699_2019-04-01_15-03-25.zip
- (198.25 KiB) Downloaded 88 times
Re: Software Axis Pairing and G Code
do you have Mill Pro installed?
No. I'm waiting to purchase when it's Router Pro.
Don't wait. You need it to pair axes. (or add the pendant) It will be a free upgrade to those with Mill Pro.
