Any thoughts on this:
https://www.ebay.com/p/CNC-Z-Axis-Slide ... 3019497624
I have an older ShopBot PRT, so I'm looking at making updates to the gantry and z axis.
Opinion wanted on z-axis
Re: Opinion wanted on z-axis
If you don't want to fabricate your own, I personally see nothing wrong with it provided it has the travel you need.robtown wrote: ↑Tue Feb 12, 2019 8:41 am Any thoughts on this:
There are other ebay sellers that sell these. I think round linear rails are old technology, but should still serve you well.
- CNC Control System Serial Number: 985DAD429EE9-0926170118
robtown,
When you select a unit for your Z axis the first thing is to ensure you have enough travel as Marty indicated. The second thing is make sure it does not have backlash. Some units use a delrin plastic nut, other use ballscrew actuators which are very accurate. Something similar to the one in the ad below. Other considerations: Weight of your spindle, do you need a brake, are you going to use a counter balance, a gear head to ensure Z does not fall if power is lost, etc.
Russ
https://www.ebay.com/itm/4671-THK-LINEA ... k:139:pf:0
Russ
https://www.ebay.com/itm/DIY-CNC-X-Y-Z- ... ctupt=true
This unit uses much better rails and looks pretty good and has 6.5" travel
Russ
Russ
Agreed, I like it much better.cncman172 wrote: ↑Tue Feb 12, 2019 4:52 pm https://www.ebay.com/itm/DIY-CNC-X-Y-Z- ... ctupt=true
Russ
- CNC Control System Serial Number: F045DA7F72E1-1119181356
check out http://www.automation-overstock.com/ for rails and ballscrew.
and https://www.industrialmetalsales.com for aluminum flat bar
You can build a z axis that is engineered by you to fit exactly what you need.
