Does any one know what the current limit is for the DB25 outputs?
I can not find any published information on these. (or the ones on the screw terminals either)
I have some SSRs that draw ~10ma and for keeping things clean I want to use the connections on the DB25 connector. I used an old parallel printer cable to make a flying lead cable, it kept the wiring to my DMM DYN2 servo amplifiers very clean.
Can someone point me to a document where this information is listed?
JoeG
ACORN DB25 Connections <answered>
Re: ACORN DB25 Connections
Try this... Should be in your docs download
- CNC Control System Serial Number: 1119181353
Thanks guys, I released after the fact that I did not post this in the acorn section.
Thanks for the links.
JoeG
JoeG
