M30 Question
- CNC Control System Serial Number: 38D2695C8301-0122180576
M30 Question
I want to change the ending coordinates when my machine ends a program. I know its probably something really simple, I think the M30 command is how to do this, but the documentation is not really clear as to how it is set up. I have probably overlooked a really simple solution.
Clint in NW Arkansas
Re: M30 Question
If there is not a file named "mfunct30.mac" in your cncm folder, make one.
Once made enter these lines:
M25 ;lifts head
G0 X## Y## ;where the ##'s are the X & Y coords that you wish the head to rapid to
M25 ;lifts head
Re: M30 Question -Answered
That was what I was looking for. Thanks!
Re: M30 Question
I'm having some trouble with the M30. At the end of the program, it doesn't execute the M30.
This is my Mfunc30:
If I call the M30 from the MDI it executes correctly.
This is the end of a program:
This is my Mfunc30:
M25 ;lifts head
G53 X23.7 Y35.8
Re: M30 Question
Add a G90 with the G53 in your macro.
The codes at the end of your program left the mode incremental (G91). G53 does not work in G91 mode.
