Awesome!. That did the trick.
Now - I want the machine to start in the home position and not have to jog it to start each time. Should I change the imput 1-4 back to Axis 1 -4 (Home) in the wizard?
Also, when I opened the wizard these last few times, it has dropped the "Paired Axis" back to non instead of the 4 and 1 as I had saved. Any reason for this?
Finally, I thought we had to import our liscens to get all of the functions provided ny the software? Or did I just select the inccorect file?
Thanks a ton.
axis' are confused
- CNC Control System Serial Number: 38D2695947FE-1222170399
Re: axis' are confused
Almost - Now when I open the software I see the "flange cnc" file loaded and it thinks I want to perform this job.
Also - the wizard keeps dropping the paired axis.
Thank you
Thank you
This version of the CNC12 software will always have the last job loaded.
It appears from your report file, you are running the free version of CNC12. Software pairing requires the Pro version. If you have the license, you load it through the F7 utility menu. Then click option and point it to where your license file is.
