Hi All,
I am looking to purchase the Centroid Acorn system.
I am wondering if it is possible to have a M function and/or similar that allows a "message box" to pop up after a G04 dwell g-code that allows the option to click OK and hence allow the program to continue running.
Please see attached G-code program. The CNC motion control software I am currently using allows this as a comment and creates a message box.
Is this possible with Acorn without a lose in position once continuing?
Thanks in advance.
Questions before purchasing: Pausing in G-code
- 031_PhD_HD.txt
- Example G-code
- (25.03 KiB) Downloaded 79 times
Re: Questions before purchasing: Pausing in G-code
hello. short answer is: yes. there are several easy ways to accomplish this.
Typically M200/201 are used. from the operator manual M200 is "Stop and wait for operator and prompt for Action:
These M codes are used for many different types of custom messages and actions.
Thank you so much for the prompt reply.
Where can I get the latest version of the operators manual.
Much appreciated.
Much appreciated.
Much appreciated. Thank you.
