probe settings acorn
rangerboy347
CNC Control System Serial Number: 38d2693c4f62-0725181074
Post by rangerboy347 »
is there a setting so after a z probe the probe will retract? i have a nc standard probe not the one from centroid.
Re: probe settings acorn
rangerboy347 wrote: Wed Sep 12, 2018 11:14 am is there a setting so after a z probe the probe will retract? i have a nc standard probe not the one from centroid.
Can you explain a little more what you are trying to do exactly?
rangerboy347
if i am using probe to set z height offset it will prove down touch part and zero then just stay at zero point. there must be a way to make it move up a certain distance after it sets the z zero offset.
hello. hit "tool check" after probing and setting the Z zero (WCS) to retract the tool from the work.
rangerboy347
well yea i know that i was just wondering if there was a setting to change it automatically no big deal
hello. by definition the Probe Z cycle stops at the detection point so the operator has a chance to set the WCS for Z at that location. if it just retracted to some other location you would lose the probed position.
