As stated, Vectric software has an added feature in that they now support Inverse Time (G93) feedrates. You MUST be using "Version 9.5" of Aspire, VCarvePro or Cut2D Pro to use these posts.
Attached are 2 posts. One that wraps Y to A and the other that wraps X to B. Select the one that matches your machines configuration. Don't forget to remove the ".txt" file extension to allow the post to be read.
Once copied into your postP folder, reboot your Vectric software and it should be visible for use.
DISCLAIMER: These have been tested and verified as working, but have not been tested on every combination of machine/rotary available. Make sure that you aircut a file or two prior to using on an actual file.
Centroid Rotary G93 (inverse time) Post Processors for Vectric Software
