Do you have additional documentation on Parameter 4? this is all I found... Nothing about adding 8 or a value of 5 - mine was set to 9 no mention of that either.cncsnw wrote: ↑Fri Dec 13, 2019 6:48 pm Sorry, I did not take the time to watch the above video to see that he was specifically talking about using the Windows file load dialog (adding 8 to Parameter 4).
The "Advanced" option is an option for the native Centroid file load screen. To use that screen, you would set Parameter 4 to a value of 5.0.
Starting CNC without Last program Run Default
Re: Starting CNC without Last program Run Default
Clint in NW Arkansas
p4 is "bitwise" that means you add the values up of the features you want and enter that value for p4
the value of 9 comes from adding feature with value of 1 and feature with value of 8 together = 9
