quill on cnc benchtop mill
I have a Pm25mv mill i'm starting to convert. sitting here at work thinking about it i have a question. what do you guys do about the quill. the z axis motor will move the head up but the quill in not controlled. i'm planning on using tts holders so i don't have to retouch of tools so much. should i just lock it at top of travel and forget about it?
Jeremy
Pittsburgh, PA
Pittsburgh, PA
Re: quill on cnc benchtop mill
YES! Lock the quill. Move the head up and down the dovetail column in true bed mill fashion.galyion wrote: ↑Thu May 31, 2018 10:22 pm I have a Pm25mv mill i'm starting to convert. sitting here at work thinking about it i have a question. what do you guys do about the quill. the z axis motor will move the head up but the quill in not controlled. i'm planning on using tts holders so i don't have to retouch of tools so much. should i just lock it at top of travel and forget about it?
Re:- Acorn rev 4, can the "P10" connector be used with a glass scale connected to the quill and some how summed to the Z axis, have been searching the forum but not making much headway
Regards
AndyB
Regards
AndyB
It MAY be possible, perhaps Marc or someone else will chime in. That encoder port was intended for use with a spindle encoder.
That said, the encoder signal must be +5V Line Driver differential. You would also need to know what pulses the scale puts out.
CNC12 can do this, but the Acorn wizard cannot. You will have to manually change parameters to get this configured and anytime you use the wizard the changes will get overwritten.
- CNC Control System Serial Number: 0479B7ADF2F3-1127192707
Franco has a good video on this.
https://youtu.be/SzDwRP3_zjc
TB131 although for CNC7 "seems" to be the right direction - i have tried it on a offline version (Demo) of CNC12 - parameters seem right, DRO displays as should, can anybody confirm if i am barking up the right tree here
Regards
AndyB
Regards
AndyB
That's an interesting setup option, particularly for knee / turret mills although it will a) prevent use of the spindle encoder and presumably b) occupy your 4th axis space within CNC12, preventing use of a rotary unit?
