I nave a Acorn Control hooked up to a known working Mach 3 System using a MKX-IV control with Centent 142 All motors work in both direction under Mach 3.
When hooked up to Acorn the Motors power up, When jogging the steppers all three axis will move only in the Positive direction, When the negative key is pressed the control thinks the motor is moving but it is not. Does anyone have any ideas as to why motion only in positive direction.
Motor Direction Control
