Well got my centroid to England and just doing bench testing - everything up and running (so easy)
I know i've seen it somewhere but can't find it again is how to get the dro to increment properly in metric?
Display does show mm/m, but i get this:
x1 moves 0.003
x10 moves 0.025
x100 moves 0.254
Bear with me, i'm moving over from the dark side (mach)!
metric DRO's
Re: metric DRO's
Re: metric DRO's
thanks Keith, knew i'd seen it somewhere...that's one hell of a manual to sift through...but i'm trying
Re: metric DRO's
set p40 to whatever mm amount you want x1 button to move:-)
f1 setup, f3 config, (type in pass '137') , f3 parameters...go to Parameter #40 enter .01 mm and the x1 button will move .01 mm each time you press it.
