At the completion of a job I'd like it to load the no_job_loaded.cnc file automatically.
I've not found any documentation to accomplish this in the GCode file itself. Is this actually possible?
Thanks in advance.
Chaining GCode File
- CNC Control System Serial Number: B4107B77A373-0905248481
Chaining GCode File
Re: Chaining GCode File
Oddly some of Uwe's vids popped up on my feed.
at 27 secs you can see G65 filename. Would that not work?
1 user liked this post
From the "Configuration" chapter of the Centroid operator's manual:
15.4.206 Parameter 401 – Forget Last Job Loaded
Setting this parameter to a value of 1.0 will cause the last job loaded to be forgotten and replaced with the name
“no_job_loaded.cnc” when the CNC software is started.
