VCP buttons with user prompts and no Cycle Start
corbin
CNC Control System Serial Number: 3484E42757Cd-1018248693
Post by corbin »
Hi!
I have a simple VCP button that calls a macro via <run>. The macro does:
M224 #101 " Enter Tool Number Currently in Spindle "
So, I type in a number and hit enter.
Then I have to hit Cycle Start before the next lines in the macro are executed. How can I avoid hitting cycle start?
Corbin
Sword
Re: VCP buttons with user prompts and no Cycle Start
Post by Sword »
I posed this question as well, and received a reply on it, but I can't find it now and I don't recall what the answer was. I think it has to do with how the enter key is used in several of the new part setup screens along with other situations. It's a change that I don't care for either, as I also have several macros that ask for input with M224, and they now take twice as many keyboard Enters than they previously did after answering input. :(
How to avoid it? ....It doesn't happen with the touch screen, external, or MPG Cycle Start, so I try to use those instead for now, but the keyboard is where my fingers are at when answering input and the enter key has 20+ years of muscle memory built in. Yes, I can hear it, "just hit enter again then if your finger is there". :(
Scott
The easiest way to fix this is to go in the wizard under "CNC Control" and set "PC Keyboard - enter key = CNC Machine - Cycle start" to yes. Then when you type in the tool number and hit enter it is the same as hitting cycle start.
Allin1Chris
Post by Allin1Chris »
corbin wrote: Sun Nov 10, 2024 8:52 pm Hi!
Corbin
Hello Corbin,
M224 will always ask for Cycle Start after the input. This is for safety as machine motion may start after the M224 Command (it acts as a operator stop, like M0). Entering the number, then pressing Cycle Start instead of Enter will do both Enter and Cycle Start.
Centroid PLC Tutorial Videos
sword wrote:.It doesn't happen with the touch screen, external, or MPG Cycle Start, so I try to use those instead for now, but the keyboard is where my fingers are at when answering input
You could try using Alt-S, which is the keyboard equivalent for Cycle Start.
the CNC12 operator manual has new information related to the M200 series m codes as well starting on page 288
Sword
Post by Sword »
cncsnw wrote: Mon Nov 11, 2024 3:14 pm
Yep, was just going to mention that, but cross posted, so just deleted it. Easier to just hit Enter a second time than get two fingers on Alt-S. ;)
Scott
Sword wrote: Mon Nov 11, 2024 3:22 pm Yep, was just going to mention that, but cross posted, so just deleted it. Easier to just hit Enter a second time than get two fingers on Alt-S. ;)
You only need to hit ENTER once. :mrgreen:
You don't even need to press Enter the first time. Just type the response and press Alt-S.
Sword
Post by Sword »
ShawnM wrote: Mon Nov 11, 2024 4:00 pm
That no longer works with a M224 that asks for input, a second Enter needs to be keyed after the input now.
Scott
