Ether1616 Changed?
Ether1616 Changed?
Did the Ether 1616 just change or did I not order an incorrect option? I believe, when I placed the order the output relays were on the same Ether 1616 board. What I received is what now appears on the site with Ether1616 with 2 relay boards. Is there another option for the Ether1616 to have the relays on the same board. This method is going to take more real estate in the control cabinet.
Re: Ether1616 Changed?
no changes to the ether1616 since it was released.
manual is here.
https://www.centroidcnc.com/centroid_di ... _guide.pdf
most do an offset stack of the relay boards to save space.
maybe are you looking at our other expansion boards for AcornSix,Oak, Hickory etc which have on board relays and similar names?
manual is here.
My mistake. I was basing it on the 3d model. The printing on the board is PLCEXP1616. Possibly original design?
PLCAdd1616 is for Oak/AllI1DC not Acorn based boards.
1 user liked this post
The PLCEXP1616 is the version for the RedOak. I think it might also work with AcornSix.
yes that is the AcornSix PLC expansion board.
https://shopcentroidcnc.com/shop/cnc-ex ... -acornsix/
the last tight one i did i mounted on the side of the cabinet.
