Still no motor movement.
Posted: Wed Apr 17, 2024 9:23 am
Hi, today I tried to get the following to work, but nothing moved.
The acorn board is connected to my pc per instructions and I have the blue heartbeat showing on the board. So that’s ok. I am using the DB25 board, not sure if I should or not. The stepper driver is a stepper on line CL57T closed loop driver connected to a NEMA 23 motor, both items purchased as a set. I have also wired the e-stop into the system as per the wiring diagram. I am powering the driver from a separate 24v power supply then the acorn boards supply. I have the green led showing on the driver. The only thing I have changed in the software is to let the board know I am using the DB25 board. Yet I am getting know movement at all.
What is wrong. What can I look at. Thanks
