Page 10 of 29
Posted: Fri Jun 03, 2022 11:58 am
by ShawnM
Glad you're getting closer Darren. I do not use Inkscape so I'm not familiar with their commands. I tried it once but have been using Illustrator for years and didn't want to retrain my brain any more than I have to.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
With Illustrator there is a command for "convert to outlines" and when I "save as" and select "SVG" I get many more options and one of those is to convert text to outlines. Keep in mind that once you convert text to outlines you cant go back and edit the text as it's no longer text. I always save a backup of each button BEFORE I convert to outlines just in case. I have a folder with my "master" buttons in it and a template for each color so if I need a new one I can quickly create one from my templates. All with the same uniform shape and font for a professional look. I also draw "rounded rectangles" in Illustrator and I can select the radius. I also like the rounded buttons for a softer feel.
As for your gradient, I have not tried that but another member posted a pic of his VCP with what looks like a gradient buttons. Look back through this topic and you'll see a user posted his VCP with what I think you are looking for. Maybe he can offer up some tips.
Posted: Sat Jun 04, 2022 10:22 am
by Sword
Rounded rectangles should work. Text needs to be "Path to Object". Sometimes grouping can cause a problem if the groups are a couple levels deep and generally ungrouping will fix it. Simple gradients work. Any use of filters will not work. Which one of your attached svg's doesn't work?
Posted: Sun Jun 05, 2022 9:56 am
by CNCisRobot
I have cracked it for now will come back with more detail and examples!
Posted: Mon Jun 20, 2022 9:45 am
by suntravel
Sneak Preview of what's possible with 4.79 Beta for lathe....
Will go in to detail with some Mods for the WMPG later
Posted: Mon Jun 20, 2022 4:19 pm
suntravel wrote: ↑Mon Jun 20, 2022 9:45 am
cool! thanks for posting. I just went public with Acorn CNC12 v4.79 rev3 beta.
https://centroidcncforum.com/viewtopic.php?f=60&t=7354
Posted: Mon Jun 20, 2022 5:37 pm
by Sword
Here's another.
![Cool 8-)](./images/smilies/icon_cool.gif)
Posted: Tue Jun 21, 2022 1:10 am
by suntravel
Cool with build in laser disc player
Posted: Thu Jun 23, 2022 10:28 am
by suntravel
V4.79 Beta3 for mill with calculator for cutting parameters
Posted: Fri Jun 24, 2022 12:48 pm
by CNCisRobot
This is my VCP I have just built the control box but don't have a machine yet as I don't have all the parts to build it. The machine is my own design and will do milling, Laser engraving small cutting and 3D printing. So my VCP is a work in progress as I don't know exactly the work flow and buttons and macros to suit my needs. I am a complete newbie used a lathe 40 years ago and horizontal shaper, never a mill but I have time to try now, but not the money sadly. I will soon make some YouTube videos showing what I have done and also showing the interface board I have designed for proximity sensors interface to suit the Acorn board. I can upload the files if people like what I have done and would like a copy, but I have not finished all.
Posted: Thu Jul 07, 2022 1:57 pm
CNCisRobot wrote: ↑Fri Jun 24, 2022 12:48 pm
cool thanks for posting. once done, all you need to do is post a fresh report.zip and that will contain all the files needed for your customizations so anyone else can benefit from them.
