Page 6 of 14
Re: Acorn controller card question
Posted: Tue Apr 13, 2021 9:50 pm
noel-nogal wrote: ↑Tue Apr 13, 2021 9:31 pm
The machine is running now, you were right drives had to be reset the gearing for new parameters, i still have to make fine adjustments but for now it looks good, i have to work with the ATC macro but i know you are there, thank you very much for your support.
I'm glad we were able to help you with suggestions/ideas that helped move you forward.
The best thanks you can give, when are done, is take the time to take a little video of the machine doing it's thing, pan to the control panel showing CNC12 operating and post it to the Success Stories forum.
Continued luck with your project.
Posted: Thu Apr 15, 2021 11:29 am
by noel-nogal
good morning.
i am trying to post a video of my cnc, where i can find the success stories forum?
Posted: Thu Apr 15, 2021 11:44 am
noel-nogal wrote: ↑Thu Apr 15, 2021 11:29 am
good morning.
viewforum.php?f=20
You will have to upload the video to YouTube, then SHARE a link in the Success Stories forum.
Thank you!
Posted: Tue Apr 20, 2021 9:00 am
by noel-nogal
Good morning marty.
I have sensors for home on my machine, but it also got limit switches on both sides of the travel, i connected the sensors for automatic homing and they work ok, after each axis seek slowly its sensor it returns back about half inch, my question is with the limit sw. I tried to configure them in series to stop the axis in case one of the sensors fail, but i am confusing in the input wizard, home all, limit all, firstaxishomeok etc. With sensors i used this condiguration on the photo
Posted: Tue Apr 20, 2021 9:01 am
by noel-nogal
Posted: Tue Apr 20, 2021 10:44 am
If you are putting the opposite end of home switches in series for overtravel safety (Please set your soft limits up anyway) use the input LIMITALL
Make sure you are using NC switches in series or it won't work.
What version of CNC12 are you using? You didn't post a fresh report. Latest version is 4.64 and that's what you should be using.
Posted: Tue Apr 20, 2021 9:36 pm
by noel-nogal
Yes the version i am using is 4.64, for now i have the machine running with soft limits and auto homing with npn sensors.
Thank you
Posted: Wed Apr 21, 2021 4:21 pm
by noel-nogal
is there any way to change the home distance? lets say now the machine back off about .5 inch from the home sensor, it is possible to change that to lets say 1 or 2 inches? or it is a fixed by edfault?
Posted: Thu Apr 22, 2021 12:30 pm
noel-nogal wrote: ↑Wed Apr 21, 2021 4:21 pm
Why do you want to do that? Please explain and post pictures of the application.
The Homing routine is hard coded and not adjustable.
You could call a move to your desired distance with G code in the .hom file if you really need that.
Posted: Thu Apr 22, 2021 1:08 pm
by noel-nogal
Ok, no that was just a question i really don't need to move that distance, right now i am working with the automatic tool change, is there any information on the tech boulletin about how to connect the stepper drive to the acorn?
