Page 4 of 6
Re: Acorn and Emcoturn 120 with 8-tools-turret
Posted: Fri Jun 10, 2022 5:40 am
by Spartan117
Spartan117 wrote: ↑Mon Jun 06, 2022 5:34 pm
Can someone tell me how much reverse-holding-voltage should be used on a emcoturn 120?
I thought about measuring current and adjusting voltage to value where current reaches 150mA
Anyone?
Posted: Fri Jun 10, 2022 8:04 am
by tblough
V=IR so just measure the motor winding resistance.
Posted: Wed Jul 06, 2022 4:24 pm
by Spartan117
Hey guys,
just a short follow-up here for now, the "big built-thread" will be written later on, without that many questions in between^^
The lathe moves and spins now, the turret can be moved via activating the correlating output-relay.
Encoder works, spindle-speeds are tuned to the following values:
S250 261rpm
S300 316rpm
S500 498rpm
S640 640rpm
S700 702rpm
S1000 1008rpm
S1500 1511rpm
S2000 2015rpm
S2500 2516rpm
(didn't measure higher values, as they are not critical at all)
And i just found out, i didn't order the pro-license directly with the acorn, so i just bought that and have to wait now for the email^^
Next big step will be to setup the turret-PLC-functionality...
-Am i right that the ATC-files "4.6 ATC programs and instructions" from here
https://centroidcncforum.com/viewtopic.php?f=60&t=3397 are the most recent ones to get and follow?
-And will the wizard (of the actual beta 4.79 rev3) work with the .srcs from that files?
-Does anyone have any further tips and/or hints regarding the turret-setup?
Thank you and best regards,
Marc
Posted: Thu Jul 07, 2022 11:12 am
by Upnorth
Yes that is where the information is. You can look in there and figure out which one will work. Luckily for you I think there is an existing macro that should work. The counter based one probably. I am using that one but I had it modified. If you are not happy with how it works you can change it. Best to just get it working as much as possible though. There are instructions in each file. If you read through the PLC you can figure out how it works.
Turret set up hint. I do recommend having a way to quickly remove power from the turret if something goes wrong. In my case I just used a toggle switch.
Posted: Thu Jul 07, 2022 5:28 pm
by Spartan117
Upnorth wrote: ↑Thu Jul 07, 2022 11:12 am
I really hope they are working^^ I will need the gray-code-one-output-src for my emcoturn.
But if i remember correctly, Marty had his turret working with the same macro, so i am hopeful
That is the more difficult part
But after Uwe told me today about the "Find All in Current Document"-function in Notepad++, things could become a little bit easier to follow.
My biggest challenge will be to not getting lost on that many different variables
Posted: Thu Jul 07, 2022 6:05 pm
by suntravel
Next cool NP++ thing is Find ALL in ALL Open Documents if you have 2 files to compare
Posted: Sun Jul 10, 2022 1:48 pm
by Spartan117
With that old .src from the ATC-files i'd loose many new features i'd like to keep... like diagonal jogging and such things.
But for a programmer-noob like me it seems like the atc-functionality is in the newer .src-files, too. Is this true?
Is the actual .src (that comes with every new CNC12-installation-files) suitable for the 4bit-gray-code-1-output-ATC-functionality, too?
So can i go with the manual from the ATC-files, but keep the newer .src that came with the actual beta-release?
Posted: Mon Jul 11, 2022 1:29 pm
by Allin1Chris
With upcoming V4.8 the PLC from acorn incorporates the logic for ATC in the PLC by default. But the extra files and instructions from the ATC-files will still be required as well.
If you excluded the .src files, you will likely run into compile errors or hidden ATC related I/O. In addition not all m-codes are provided with the install as of yet as well.
We will have updated V4.8 ATC files soon.
Posted: Mon Jul 11, 2022 1:44 pm
by Spartan117
Allin1Chris wrote: ↑Mon Jul 11, 2022 1:29 pm
Thx for this helpful answer!
Now the question every programmer hates:
What means soon?
A software-engineer told me once:
"If a software-engineer tells you, it will take 2 days to finish the software, you have to multiply by 2 and step up the unit. That means, 2*2=4, and days go to weeks, so 4 weeks if he says 2 days.
We are not talking about such a "soon" here, i hope?
I'd be glad to test the ATC-files for the 4bit-grey-code-one-output-turret-variant
Posted: Mon Jul 11, 2022 2:31 pm
by tblough
Double the time and increment the units seems to hold for most estimates
