Page 4 of 5
Re: Build thread:Magnaturn 612 retrofit(s) - Southbend
Posted: Sun Jan 12, 2020 7:16 pm
by frijoli
martyscncgarage wrote: ↑Sun Jan 12, 2020 5:27 pm
frijoli wrote: ↑Sun Jan 12, 2020 2:16 pm
The factory home switch on the Southbend is in the middle of the Z travel. Is there an easy way to use this to home, and then move away in the + direction for inches and then set machine zero?
The X axis is normal.
Though I have never tried it, because....I would put the switch in the proper location.
I plan on adding/moving the switch, but I also plan on using the machine first! lol
I am not sure why the put the switch there. It's mounted through the casting of the bed.
Posted: Sun Jan 12, 2020 7:25 pm
by frijoli
Wiring is about 80%
Old stepper controller
Gutted and adding new Acorn
Posted: Sat Feb 01, 2020 11:31 pm
by frijoli
Quick update.
Pay attention to what is going on around you. I'll get to that in a second.
The Joki magnetic encoders work with the CNC4PC differential adapter boards(C72). Meaning I threaded parts, tapped holes and constant surface speed works with the spindle! The spindle readout in CNC12 is dead on what my test tachometer reads.
My stepper drive works for my axis ATC, although not mounted yet, nor complete. The the pulse works as well from the encoder for homing. It's the same Joki encoder with pulse out and NO differential adapter. Just connected like a proximity switch.
Pay attention! I was testing input and output responses with the encoder and I dropped a jumper wire. It landed directly accross the right terminals to kill my C86 board(CNC4PC). It still works "IF" I disconnect the fault/enable input to Acorn. Ordered another board and I am off to California for work.
I painted some of the components and started the reconstruction.I'll try and get some pictures tomorrow. This machine should be complete in about 3 weeks! Gotta find a small "paying" lathe job to run on it.
Posted: Sun Feb 02, 2020 1:42 pm
frijoli wrote: ↑Sat Feb 01, 2020 11:31 pm
Quick update.
Yup, happened to me too once Clay!
You'll get there. Now that you know machine is running around ok, clean up the wiring and button up the control cabinet....
(I'm a hippocrit, I need to do the same to my Emcoturn 140!)
Posted: Sun Feb 02, 2020 4:01 pm
by Reedfirst
Wow, that is a really nice small lathe.
I think I'm going to keep my eye out for one of those.
Posted: Sun Feb 02, 2020 9:55 pm
by frijoli
Reedfirst wrote: ↑Sun Feb 02, 2020 4:01 pm
Look hard and often!
My understanding is that there were about 300 made. I stumbled on mine.
They are pretty sturdy machines. They have design issues that make you scratch your head.
Posted: Mon Feb 03, 2020 10:48 pm
by frijoli
ATC-Turret teardown
Took the 5 pole 60mm motor and retrofitted a Nema23 2 pole. Tested it with the "cheap ass" stepper driver and it works!
Next is to get the ATC/Turret PLC in place when I get home on the 14th.
Posted: Mon Feb 03, 2020 11:21 pm
by BASE
Since seeing this thread I’ve decided I need one of them too. He’s right though, there aren’t many out there.
Posted: Mon Feb 03, 2020 11:29 pm
I think he has an extra one
![😉](//twemoji.maxcdn.com/2/svg/1f609.svg)
Posted: Mon Feb 10, 2020 3:19 pm
by frijoli
In preparation for the Turret control, I listed out what I know and also what I understand I need for Centroid/someone to write (or help me write) a PLC program.
What I know:
• It is axis driven
• 8 position turret with a lock bar(not a pawl)
• Using stepper motor for rotation (ratio = 800 pulses per tool position)
• Has index pulse output from a single rotation encoder (mounted to the turret shaft)
• Has 110vac solenoid to lock and unlock the tool position when AT location
• Can rotate in both directions
What I think I know:
Homing routine sequence:
• Home LAST in axis homing sequence, at the tool check location
• Unlock turret
• Rotate quickly to find marker pulse.
• Reverse slowly past marker pulse
• Rotate very slowly until marker pulse is re-located
• Lock turret
• Set to tool 1
Tool change automatic via G code:
• Must be at tool check location and homed
• Unlock turret
• Rotate to correct tool (bi-directional is preferred)
• Ignore marker pulse if previously homed
• Lock turret
• Change current tool number
• Continue program
Tool change MDI:
• Go to tool check location
• must be previously homed
• Unlock turret
• Lock turret
• Change to current tool number
Tool change Manual:
• Use Aux 5 and Aux 8 to increment and decrement tool position respectively
• Unlock turret
• Lock turret
