ok mercicncsnw wrote: ↑Thu Jun 01, 2023 12:43 pm The language file is the same in Mill and Lathe controls. Presumably they are the same also for router, plasma, laser, etc.).
The format of the message file generally does not change between software versions, and the content of most existing messages usually does not change. You can assume that future software releases, if they contain any significant feature changes, will include new text that was not present in earlier language message files.
Translation of cnc12 Traduction de cnc12
Re: Translation of cnc12 Traduction de cnc12
Hello, is it possible to have the photos of the intercom machining block on the performance racing interface engine block version?
To be able to finish the translation of the language file into French
Bonjour est il possible d'avoir les photos de bloc d'usinages d'intercom sur la version performance racing interface bloc moteur ?
Pour pouvoir finir la traduction du fichier langage en français
c:\cncm\bmps
merci mais il manque les textes anglais sur les photos
thank you, but the English texts on the photos are missing.
ok, let me see what i can do
I really need the photos of the performance racing engine interface.
thank you so much for your help
je vous remercie il me faut vraiment les photos de performance racing interface moteur
vraiment merci pour l'aide que vous m'apportez
so may I suggest that you register on this forum to help us finalize the translation of the engine block components? https://www.usinages.com/threads/fichie ... 514/page-3
aussi puis je vous proposer de vous inscrire sur ce forum pour nous aider à finaliser la traduction des éléments bloc moteur https://www.usinages.com/threads/fichie ... 514/page-3
Hello,
Thank you for the interest and for helping. Currently, we do not have a need to translate the block software. In the future if we have the need, we will keep you in mind.
