You guys are absolutely amazing
I will look into your guys suggestions and advice here.
I do need the button for the X0Y0 though…
The CNC is working, just needs the limit switches working and yes I forgot to press F6 to disable the rotary axis since it’s not being used.
Re: Unable to setup homing
Posted: Tue Dec 07, 2021 11:14 am
by guerra_cues
martyscncgarage wrote: ↑Mon Dec 06, 2021 8:15 pm
What is ACCS? I don't understand what you are referring to.
Centroid software is CNC12. There is a version for Centroid Acorn.
Marty,
I called ACCS - Acorn CNC Control Software but moving forward I will call it CNC12 so I can speak the same language. Thanks for the video my friend and thanks for the great videos you do!
Posted: Wed Dec 08, 2021 3:24 am
by guerra_cues
Howdy!
So It is time to update everyone that helped and unfortunately still have a few issues going on:
The good news!
The limit switches were fixed (had 2 bad switches) and I was able to home the CNC successfully! Yeah!!!!
Still having some issues after being able to Home the CNC:
I am unable to Home the CNC with the A axis enabled (F6) - it homes the axis Z, Y and X still says that the machine needs to be homed. If I disable (F6) the A axis the CNC homes and is ready to go to work. What can I do to Home the CNC and still use the A axis?
Homing X is running at 15ipm, is there a way to change that velocity?
When I was able to use the rotary, if I issued a command in MDI like A120, it's accurate but super sloooooow, where can I change that jog speed? And what is a faster speed recommended?
At the end of the day the good news is the machine works very well but need to get the A axis situation fixed.
Thanks for all the input and help guys!
Posted: Wed Dec 08, 2021 10:22 am
by CNCMaryland
Do you have the Pro version of the software?
The slow jog speed is your homing speed. I run homing at 500mm/min ~ 20ipm
Posted: Wed Dec 08, 2021 10:54 am
by guerra_cues
CNCMaryland wrote: ↑Wed Dec 08, 2021 10:22 am
I do have the Pro version of CNC12. What about the speed on the A axis?
I’m not able to understand why I can’t home the machine with the A axis enabled (F6), I do not have any limit switches on my rotary.
Posted: Wed Dec 08, 2021 11:41 am
by tblough
If you are using G0 when you move the A-axis using MDI then the speed is set with the fast jog setting in the Wizard. If you are moving the A-axis in MDI using G1, the then feedrate is set using the Fnnn word.
Posted: Wed Dec 08, 2021 11:56 am
by guerra_cues
tblough wrote: ↑Wed Dec 08, 2021 11:41 am
I am sorry Tom what do you mean by using the Fnnn word?
