Top Images shows one direction and other lower images shows the other direction.
MaxNC15CL to Acorn
- CNC Control System Serial Number: M400 ATC SN: 6998
M400 ATC SN: 6768
M39 ATC SN: 10145
M400 SN: 20313 - DC3IOB: No
Re: MaxNC15CL to Acorn
Maybe this? https://www.utex.com/webapps/utexhome.n ... D3458?Open
You'd probably be better off in the long run just replacing the motors with something more current.
Well, no Acorn only outputs step and direction.
You may as well upgrade to new stepper drivers and stepper motors.
M400 ATC SN: 6768
M39 ATC SN: 10145
I would like to reuse the motors if possible. Below are the motor specs. It is a Nema 23, 2 phase Hyrbrid Stepper Motor. Would this be considered a "standard" stepper motor?
Would these motor drivers work with the existing motors..
I asked the seller if these would work with my motor. He said it should work if the motor is 2 phase and under 4 amps. The machine currently has 2.3A 71W motors.
Beauty Star Stepper Motor Driver, 3PCS TB6600 4A 9-42V Nema 17 Stepper Motor Driver CNC Controller Single Axes Hybrid Stepper Motor Controls
https://smile.amazon.com/dp/B077MDVTF9/ ... _lig_dp_it
M400 ATC SN: 6768
M39 ATC SN: 10145
Do you think there is any chance the Centroid Guys would add the Quadrature Option to the Acorn? It was built in Mach3. I am sure there are quite a few MaxNC machines still out there. Below is the Config screen in Mach3 that allows you select Quadrature.
Yes they appear to be standard steppers, but you didn't give the specific model number.doucetw wrote: ↑Mon Mar 11, 2019 5:58 am I would like to reuse the motors if possible. Below are the motor specs. It is a Nema 23, 2 phase Hyrbrid Stepper Motor. Would this be considered a "standard" stepper motor?
MaxNC_Motor_2_PN_P22NRXB-LDN-NS-00_pacificscientific_series_powermax_ii_manual_en.pdf
MaxNC_Motor_PN_P22NRXB-LDN-NS-00_pacificscientific_series_powermax_ii_manual_en.pdf
Do you know the stepper power supply voltage?
I'd be wary of cheap drives. You usually get what you pay for. You can certainly try.
You need to know the current model stepper so you can look up the current and voltage specs. Having the inductance value can help calculate the power supply voltage too
I can't answer to the square wave thing, but probably unlikely. Step and direction control is pretty standard
M400 ATC SN: 6768
M39 ATC SN: 10145
The Motor Part Number is P22NRXB-LDN-NS-00.
65V
65V
