aceeleration in .nc code
- CNC Control System Serial Number: c8fd19c4ab47-0214180670
Re: aceeleration in .nc code
report file
- report_C8FD19C4AB47-0214180670_2018-06-27_19-40-00.zip
- (1.02 MiB) Downloaded 86 times
please upgrade to v4.12
http://www.centroidcnc.com/centroid_diy ... loads.html
follow the upgrade video instructions Exactly.
https://youtu.be/ZYmtJBEIMuQ
dear friend, it worked only axis X, I could enter the value of 126.5 but only on the X axis, I need on the Y axis also be able to enter a value equal to or greater than 126.5, so I need it on the X and Y axes
in the X axis can even put a value higher than 140, so the modification worked, a penalty that only in the X
Report file
- report_C8FD19C4AB47-0214180670_2018-06-28_18-08-53.zip
- (177.43 KiB) Downloaded 113 times
cnc12 is compatible with Windows 10 only.
the report.zip file shows that you are running Windows 7
friend, I take the time to program it in windows 10 and it does not allow me in the Y axis to put a value higher than 39.4
please I ask that the same permission I use on the X axis, do it on the Y axis,
and under windows7 it works perfectly, I do not have any problem, the restriction is of the cnc program in overall turn ratio
please ask, I have invested a lot of money and time, since the beginning of this post I commented that my problem was not being able to enter a higher value in "overal turn radio"
please I ask you to pass me a corrected version
I wait for your news
if you try it yourself you will realize that you can not enter a value greater than 39 on the Y, Z axes
i have tried my self. it works fine.
can you install teamviewer 12 and get an internet connection to the cncpc?
could you modify the value on the X and Y axes?
the machine is in the workshop where I do not have internet, but I could try
are you online now?
I have the teamviewe
are you online now?
my teamviever id is 1 078 549 991,
the pasword 6321
the pasword 6321
when i try to connect...says no connection..
viewtopic.php?f=61&t=1448
please set up a permanent password and private message me.
