Please don't take offense. Some times we miss the basics.Dave_C wrote: ↑Mon May 14, 2018 2:00 pm Look up thee post earlier and you'll see the exact make and model of the encoder. [Encoder Model #TRDSH2500-VD, from Automation Direct.}
We have covered this before in this same thread. The wiring is exact per the Acorn drawing, the cable has no extension and is the cable attached to the encoder which is shielded and it is grounded at the Acorn end only! It is only 6 feet long, does not parallel any other cable, enters the control cabinet in its own entry hole and has a modular plug that can be removed if I need to.
The RPM reads just fine at any speed, high or low and it is accurate! So factory wiring except for the DB9 connector! I've gone to the trouble of putting a bar into a holder in the spindle so I can turn the spindle as close as I can to a perfect 1 turn and I get 10,000 pulses on every turn. So it is not wired wrong else it would not be giving me proper pulses!
I'm pretty much down to a noise issue or just crappy encoders! If it is noise, I have no idea what or where it is coming from or how to eliminate it!
Dave C.
I used the cut sheet for the Line Driver Connections: https://cdn.automationdirect.com/static ... oderld.pdf
So you are wired with a shielded cable:
Encoder Blue (0V) - DB9 Pin 2
Encoder Brown (+5VDC) - DB9 Pin 9
Encoder White (A) - DB9 Pin 7
Encoder Gray (/A) - DB9 Pin 4
Encoder Purple (B) - DB9 Pin 8
Encoder Black (/B) - DB9 Pin 5
Encoder Orange (Z) - DB9 Pin 6
Encoder Yellow (/Z) - DB9 Pin 3
Encoder Shield - DB9 SHELL
Also, the Acorn schematic for the DB9 is as you are looking at the female connector on Acorn.
If you used solder cup DB 9 male connector, double check there are no "whiskers" touching another pin?
Just trying to double check the basics.
