Larry, read the manual for your drive and it'll tell you what 7 flashes means. We cannot know as we don't have the manual or even a link to your manual to tell you what's wrong. Download and read your drives manuals and you'll know what is happening. The Acorn is showing drive fault because you wired the ALM circuit from the drive to the Acorn. Sounds like an encoder wiring issue to me.
Secondly, those drives should be wired to the DB-25 port and not the Acorn headers. This could be another source of issues down the road.
Drive Faults, Homing, Slaving... where to begin?
- CNC Control System Serial Number: 0035FF98C2BC-0421214705
Re: Drive Faults, Homing, Slaving... where to begin?
Thanks for help where can I find DB -25
manual
1 The value of position following error is set to small
2 Motor wiring error check wiring
Can't figure out why it work at first not second day
Thanks for the help
Larry
manual
Thanks for the help
Larry
Larry, please start a new thread. Click on START A NEW TOPIC on this page: viewforum.php?f=60Iflyb777 wrote: ↑Mon Jun 07, 2021 4:26 pm 20210607_152127.jpgI am new to cnc world, I have acron using CNC12 doing bench test with 1 driver KL5080d4 motor KL 23 31n-1000, day I received it got to work fine next day started up CNC12 move Z axies motor turn about one step then I get Drive fault 9031 all so getting 7 red flashes on drive
Need help
thanks Larry
Please provide details of your build, make and model (including link to the manuals) of the axis drives/motors you are using.
Follow this post to provide us more information to help you: viewtopic.php?f=60&t=1043
Found db25 cable
Ok will start new topic
You don't need a cable, you need one of these from Amazon to wire the drives to:
https://www.amazon.com/D-sub-DB25-Break ... s&sr=1-15
and the wiring diagram along with ALL the documentation for the Acorn can be found here:
viewtopic.php?f=60&t=3397
That error code tells me to check the encoder wiring, maybe you bumped a wire loose or it has a bad connection.
Order DB 25 off Amazon I have ck wIring thanks for help
Larry
Larry
