Switch failed to clear during homing <resolved, switch arm too long>
Re: Switch failed to clear during homing
Great. Good information.
the machine looks decent, just needs some simple tweaks to get the most out of it. looks like the screws are 2.5 turns per inch? on X and Z?
if so, when you get new AC brushless motors belt the X motor 1:1 with the screw so the turns ratio will be the screw pitch (2.5) 2.5 turns per inch for X and Y is about perfect for the type of work you are doing. keep the Z belted the way it is.
How is the Y driven? screw? or rack? photos please.
I would put an AC 750 Watt brake motor on Z and a AC 750 watt motor on X. and i can comment on Y when i see photos.
The Y is direct drive. And the same pitch . Just a centered ballscrew.
great.. dual screws or one down the middle?
Got the problem resolved modified the arm the limits hits and that shorten up the distance the limit moved.
