Snubbers Work!
Re: Snubbers Work!
Marty, Not sure what happened there. I edited the post.
Clay
near Winston-Salem, NC
- CNC Control System Serial Number: 38D2695C8301-0122180576
Re: Snubbers Work!
I re-wired the snubbers across the coils. And still got a comm error. Any ideas?
Clint in NW Arkansas
Re: Snubbers Work!
What kind of machine is it?
Can you please post a high resolution of the control cabinet?
Did you wire it all?
If you have a VFD, turn it off and test again to see if you get the comm error.
If that doesn't do it, and you continue to get comm errors, disconnect these one at a time testing as you disconnect them:
Spindle Analog output
Output connector(s)
One bank of input connectors
Second bank of input connectors
Try and isolate where the noise is coming from.
Output connector(s)
Re: Snubbers Work!
martyscncgarage wrote: ↑Mon Dec 30, 2019 7:08 pm What kind of machine is it? It is a 9 years old NewCNC machine, they imported a heavy-duty Chinese frame and put Yaskawa sigma 2 drives, a delta VFD and a 6HP Chinese ATC spindle, a two PLCs, and spindle break-out board, a PMDX board, and smooth stepper board with Mach3 to drive it all.
Can you please post a high resolution of the control cabinet? I'll try to clean up all the stray wires and get a good picture.
Did you wire it all? No, I replaced the controls with Acorn and kept everything else.
If you have a VFD, turn it off and test again to see if you get the comm error. My original test was without the spindle running and I e-stopped 20-30 times while doing MDI moves and no comm errors, Now the only times it has comm errors is during a job when the spindle is running. The comm errors are MUCH less frequent now though.
Output connector(s)
Re: Snubbers Work!
Ah, I remember the beastie now....
Re: Snubbers Work!
One thing I discovered was that my 24VDC power supply was only outputting 18.5VDC could this contribute to the connection issues?
Re: Snubbers Work!
It's possible. Lower voltages are more susceptible to noise. Can the voltage be adjusted? Is the low voltage being caused by the supply being overloaded? How much noise/ripple is present on the supply lines?
Re: Snubbers Work!
tblough wrote: ↑Sun Jan 05, 2020 9:20 am It's possible. Lower voltages are more susceptible to noise. Can the voltage be adjusted? Yes I was able to adjust it to 22.5 volts.
Is the low voltage being caused by the supply being overloaded? To be honest I never even checked it. But this system has a fan, solenoid valves, and I am using CNC4PC's C86 RJ45 board that requires DC power. Would that be considered overloaded? I have an industrial 24VDC power supply I could drop in.
How much noise/ripple is present on the supply lines? I don't have a means to check/measure this.
Re: Snubbers Work!
Is this a separate power supply? Not Acorn's logic power supply? Good quality? I would replace it. Further you need to connect the commons of the logic power supplies together.cbb1962 wrote: ↑Sun Jan 05, 2020 9:44 amtblough wrote: ↑Sun Jan 05, 2020 9:20 am It's possible. Lower voltages are more susceptible to noise. Can the voltage be adjusted? Yes I was able to adjust it to 22.5 volts.
I would put those prox sensors on Acorn's power supply. Get the 24VDC from the input 24VDC input terminal, (the one open) and Common and retest.
Re: Snubbers Work!
There is a problem with the C86Acorn board, rev2. They just released a rev3. I have not tested it yet.
If your green light is not on, its not working right....contact CNC4PC for a replacement. Yes it appears to work, but it expects ALL enables to come on at the same time and they don't always.
