Page 2 of 2
Re: Bridgeport EzPath Lathe,Acorn Board & Handwheels
Posted: Fri Jul 28, 2023 11:49 am
by centroid467
Happy to help! Post pictures of the machine when you have it all running!
Posted: Thu Sep 14, 2023 8:04 am
by FC84
I am having trouble getting the ROD 426 spindle encoder to work with the acorn6 encoder input and I think it may be related to the current draw which can be up to 120 mA. Is there a way to use an external 5v power supply rather than the acorn6 5v supply? For the gecko drives, I was successful using 470 ohm resistors as discussed in this thread:
https://www.cnczone.com/forums/gecko-dr ... upply.html
Posted: Thu Sep 14, 2023 9:22 am
by centroid467
The simplest way that does not involve cutting up existing cables is to make a short patch cable that breaks out the +5V line. Make sure the power supplies share a common negative.
- This ought to work
Posted: Mon Mar 04, 2024 2:49 am
by FC84
I decided to test with one of the lathe handwheel encoders first (ROD 426.0000-600). I connected the x axis encoder to a 5V power supply and common negative as recommended. Only A/A- and B/B- were used by the old ezpath controller, so I as those were the only wires I could match to a schematic I connected those and configured the encoder port for x axis MPG input. I don't get an error, but I don't get any servo motion either. Is there anything built in to CNC12 to help troubleshoot?
Will the acorn6 work with Only A/A- and B/B-, or do I need Z/Z-? I checked with a multimeter and the A/B voltages bounce between 0.2V and 3.3V as I turn the handwheel so it seems like it is outputting reasonable signals.
Posted: Mon Mar 04, 2024 8:05 am
by tblough
Index pulse is not used by handwheels.
Posted: Mon Mar 04, 2024 10:27 am
by FC84
Thanks, so if z/z- is not required and I checked the hi/low signal voltages, is there anything else you'd recommend for troubleshooting?
